lpcware
Problem with FPU and double calculation
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by h.lotfi on Wed Oct 15 01:22:12 MST 2014
i have problem with hardware fpu and double calculation!
when i use float variables and enable FPU and initialize it, i can calculate any things, but when i change variables to double the micro
get stick in the line which I calculate double variables and micro could not pass that line!!!
this is my code:
double f=, ff=;
//float f, ff;
        count = 0; // init counter
f = 1.000001;// pick initial values that will prevent over/under-runs
ff = 0.999999;
msec = 10000;// run the test for ten seconds
do {
//ff *= f;// test of multiplication
ff =ff/ f;// test of division
count++;
count /= 10;
} while(msec);
but when i add an function micro work correctly!!!
this code Work:
double f=, ff=;
//float f, ff;
ff = 0.999999;
do {
               sprintf(str,"Num:%d\r\n",count);
count++;
count /= 10;
} while(msec);
any body know what its for?
i use LPC4357 and Keil
