Content originally posted in LPCWare by bavarian on Mon Nov 05 11:09:44 MST 2012
in the current devices of LPC43xx the ROM library for SPIFI is not functional.
Therefore you need to link it from external into your application program.
38kbyte is of course the file size on the PC file system, the amount of code linked into your application program is of course less than that (look into the map file after compilation).
NXP Tech Support Team
