lpcware
Executing code from SPIFI while also using serial flash for data storage?
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by mirfan on Fri Feb 01 00:49:16 MST 2013
I am using LPC4350's SPIFI interface for executing code from serial flash. What i need to know is that is it possible that the serial flash connected to SPIFI (from which code is being executed) be also used as a normal flash memory for general purpose data storage. Can I write data to the serial flash using SPIFI interface and run code from it simultaneously?
Irfan
