Hi, did you get this solved? What ltib are you using? I'm using 20061117. With this build it works to use mount -t vfat /dev/sda1 /mnt/flsh. (create a /mnt/flsh directory) I think the new ltib uses uba instead of sda.
Are you using romfs? If so the /dev directory is readonly. You can edit ltibxxxx/bin/device_genromfs.txt and add a line:
uba1,b,125,0
When you rebuild your romfs you will have /dev/uba1
Message Edited by obidon on
2008-06-13 10:58 PM
