Content originally posted in LPCWare by Heikon on Tue Dec 04 03:29:35 MST 2012 as I tried to config the port and pins for our application I got the problem, that EMC_D5 and SD_DAT3 are on the same Pin and no other configuration is possible. did I overlooked something or can I only use one of those interfaces? thanks heiko
Content originally posted in LPCWare by DF9DQ on Tue Dec 04 03:44:59 MST 2012 That is the unfortunate truth. Only the LBGA256 package can use external memory and wide SD card bus together, but none of the smaller packages. :-(
