Content originally posted in LPCWare by Thiapalm on Thu Mar 31 12:22:09 MST 2016
We have an application that uses ADC, MCPWM and CAN.
We have been experiencing CAN problems and after some research, we have found the Errata sheet LPC435x/3x/2x/1x flash-based devices mentioning BUS problems between CAN and the mentioned devices.
However, on the LPC43xx Datasheet from 15 of March 2016 (v5.3), it is said that the problem is solved since version v3 from 2014/08/19.
" Removed restriction on C_CAN bus usage. See CAN.1 errata in Ref. 2."
Is it really solved?
If so, how can I identify the "fixed" Chips?
Thx
