lpcware
math.h on 43xx
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by ArriaLive on Sat Nov 08 17:05:17 MST 2014
I'm trying to use some fairly basic math.h functions (including sinf() and cosf()) in a project that is running on an LPC4330.  I am using the FPv4-SP (Soft ABI) floating point library as recommended by these forums.  I can work with float numbers--add, subtract, multiply, divide, etc., but when I add the math.h functions (even in single-precision floating-point mode), I get a hardfault with a NoCP (no coprocessor) fault.
Here's my test code:
/* This one works */
float testfunction(void) {
  float a,b;
  a = 2.5F;
  b = 2.0F*a;
  return b;
/* This one gets a hard fault (NoCP) */
  float a,b;
  a = 2.5F;
  b =sinf(a);
  return b;
Any ideas what I'm doing wrong?  Am I missing a parameter somewhere?
