Content originally posted in LPCWare by srinu282 on Fri Jul 13 03:15:28 MST 2012 Hi All, AM having Hitex development board:LPC4350.i want dual core IPC code for LPC4350.i got the dual core code from following link http://www.lpcware.com/content/contribproj/lpc43xx-dual-core-freertosx2-project-ipc. 1.m0 project built with FLASH configuration. 2.M4 project built with FLASH configuration. 3.JUMPERS: BOOT1 : 1-2,BOOT2 : 1-2,BOOT3 : 3-4,BOOT4 : 3-4(I need to boot from EMC 16 bit). 4.loaded image in to board using ULINK2. 5.started debugging using ULINK2.both cores are communicating and M4-RED,M0-bule,shared memory-Blue leds is blinking. Till here every thing is working fine. when i RESTART HITEX board getting "HardFault_Handler " Exception and stopping here. i want to run dual core program from EMC 16bit on Hitex board : 4350. please help me to get out off this problem ..
