void Hal_PWMInitialise(void) { PWM_TIMERCFG_Type PWMCfgDat; PWM_MATCHCFG_Type PWMMatchCfgDat; size_t i; // Initialize PWM peripheral(s). PWMCfgDat.PrescaleOption = PWM_TIMER_PRESCALE_USVAL; PWMCfgDat.PrescaleValue = 10U; PWM_Init(BRD_OUTPUT_CHANNEL_LC_FET_PWMA_PERPH_N, PWM_MODE_TIMER, &PWMCfgDat); PWM_Init(BRD_OUTPUT_CHANNEL_LC_FET_PWMB_PERPH_N, PWM_MODE_TIMER, &PWMCfgDat); // Master disable for PWM0 and PWM1 peripherals. LPC_PWM0_TCR |= (1 << LPC_PWM0_TCR_MDIS_BIT); // Initialize PWM pin connect. for (i = 0; i < N_ELEMENTS(m_OutputChannelLowCurrentLayout); i++) { GPIO_SetDir(m_OutputChannelLowCurrentLayout.port, (1U << m_OutputChannelLowCurrentLayout.pin), GPIO_DIRECTION_OUTPUT); PINSEL_ConfigPin(m_OutputChannelLowCurrentLayout.port, m_OutputChannelLowCurrentLayout.pin, BRD_OUTPUT_CHANNEL_LC_FET_PWM_FUNC_NO); } // Set match value for PWM match channel 0 and update immediately. // PWM levels are set between 0 - 1000ppt (0 - 100%). A level of 100% = 1000ppt. /* 26.4.1 Rules for Single Edge Controlled PWM Outputs 1. All single edge controlled PWM outputs go high at the beginning of a PWM cycle unless their match value is equal to 0. 2. Each PWM output will go low when its match value is reached. If no match occurs (i.e. the match value is greater than the PWM rate), the PWM output remains continuously high. */ PWM_MatchUpdate(BRD_OUTPUT_CHANNEL_LC_FET_PWMA_PERPH_N, 0, (BRD_OUTPUT_CHANNEL_LC_FET_PWM_PERIOD - 1U), PWM_MATCH_UPDATE_NOW); PWM_MatchUpdate(BRD_OUTPUT_CHANNEL_LC_FET_PWMB_PERPH_N, 0, (BRD_OUTPUT_CHANNEL_LC_FET_PWM_PERIOD - 1U), PWM_MATCH_UPDATE_NOW); // PWM Timer/Counter will be reset when channel 0 matching PWMMatchCfgDat.IntOnMatch = ENABLE; PWMMatchCfgDat.MatchChannel = 0; PWMMatchCfgDat.ResetOnMatch = ENABLE; PWMMatchCfgDat.StopOnMatch = DISABLE; PWM_ConfigMatch(BRD_OUTPUT_CHANNEL_LC_FET_PWMA_PERPH_N, &PWMMatchCfgDat); PWMMatchCfgDat.IntOnMatch = DISABLE; PWM_ConfigMatch(BRD_OUTPUT_CHANNEL_LC_FET_PWMB_PERPH_N, &PWMMatchCfgDat); // Configure each PWM channel. for (i = 0; i < N_ELEMENTS(m_OutputChannelLowCurrentLayout); i++) { PWM_ChannelConfig(m_OutputChannelLowCurrentLayout.pwm, m_OutputChannelLowCurrentLayout.channel, PWM_CHANNEL_SINGLE_EDGE); PWM_MatchUpdate(m_OutputChannelLowCurrentLayout.pwm, m_OutputChannelLowCurrentLayout.channel, 0, PWM_MATCH_UPDATE_NEXT_RST); PWMMatchCfgDat.IntOnMatch = DISABLE; PWMMatchCfgDat.MatchChannel = m_OutputChannelLowCurrentLayout.channel; PWMMatchCfgDat.ResetOnMatch = DISABLE; PWMMatchCfgDat.StopOnMatch = DISABLE; PWM_ConfigMatch(m_OutputChannelLowCurrentLayout.pwm, &PWMMatchCfgDat); PWM_ChannelCmd(m_OutputChannelLowCurrentLayout.pwm, m_OutputChannelLowCurrentLayout.channel, ENABLE); } // Reset counter. PWM_ResetCounter(BRD_OUTPUT_CHANNEL_LC_FET_PWMA_PERPH_N); PWM_ResetCounter(BRD_OUTPUT_CHANNEL_LC_FET_PWMB_PERPH_N); // PWM mode enable. PWM_Cmd(BRD_OUTPUT_CHANNEL_LC_FET_PWMA_PERPH_N, ENABLE); PWM_Cmd(BRD_OUTPUT_CHANNEL_LC_FET_PWMB_PERPH_N, ENABLE); // Start counter. PWM_CounterCmd(BRD_OUTPUT_CHANNEL_LC_FET_PWMA_PERPH_N, ENABLE); PWM_CounterCmd(BRD_OUTPUT_CHANNEL_LC_FET_PWMB_PERPH_N, ENABLE); // Master enable for PWM0 and PWM1 peripherals. LPC_PWM0_TCR &= ~(1U << LPC_PWM0_TCR_MDIS_BIT); } |
