lpcware
FDI-LPC3250-Ethernet Diconnecting Issue
Content originally posted in LPCWare by Pradeep Kumar on Wed Jan 08 06:30:32 MST 2014
I am using LPC-3250 custom board ported with kernel 2.6.34.For file system mounting i'm using ramdiskboot and mtdboot procedures.When the board is getting powered in that time ethernet is connected properly and i'm running applications on board .But after some time in both the booting procedure  ethernet getting disconnected. In H/W side on board ICS1893AFI IC is mounted for ethernet interfacing.
  The following dmesgs are getting when i'm using ramdiskboot procedure
   nfs: server 192.168.1.10 not responding, still trying
How can i recetify this issue on LPC3250.Can any one suggest me to get out of this issue.
Thanks In Adv &  Regards,
Pradeep Kumar G.
