Content originally posted in LPCWare by MOHAMMAD BIYABANI on Thu Mar 07 21:36:16 MST 2013
I am trying to setup the development environment for an New Board that contains (LPC3250) ARM9 controller,SDRAM (MT48LC32M16A2P) with memory size of 512Mbits and NAND FLASH.when I tried to cross-compile the kernel and load it on the board(in NAND FLASH),the console showing the message
Uncompressing Linux... done, booting the kernel
To identify what is the problem i need kernel base address, i tried to found the address but i did not got it. So, I want to know which file contains kernel base address?
Thanks & Regards.
