lpcware
Lpc1857 double writes to memory
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by enyi on Sat Feb 15 08:33:30 MST 2014
My problem is double writes to memory when ever i do a single write to a memory address.
For example if do following write function
uint8_t *ptr = 0x1C000000;
*ptr =0x00;
This results in following:
0x1C000000 = 0x00
0x1C000020 = 0x00
This second write to the address 4 bytes after original intended address occurs at the same time.
Does anyone know how to fix this problem or do i need to use the lpc4357 instead
