Hi everybody,
what happens when supplying the Hitex LPC18xx Board accidently with 9V instead 5V? I've seen no fuse or voltage regulator for the 5V supply which protect the board :-( The 3.3V supply has a voltage regulator but it tolerates max. 6.5V. Now I get the error message "target not debuggable". Have I damaged the Board or is it just in a protection mode? Is it possible to rescue it?
Martin
