Content originally posted in LPCWare by ancuk on Thu Apr 24 07:58:34 MST 2014
Great, Wouter,
That's fantastic news - will use this later today and report back. Many thanks, for now.
Cheers,
Manny
OK - just tried the modified inf file ....... but still getting a CODE 10 error.
I had mistakenly written down wrong info with respect to the [DEVICE] line in the original inf file - not sure if this would've made a difference?
The original lpc18xx-vcom.inf file had the following line in it:
[DeviceList]
%DESCRIPTION%=LPC18xxUSB, USB\VID_1FC9&PID_2002
.............but when the hardware was interrogated (using 'DEVICE MANAGER - RightCLICK on LPC18xx USB Vcom Port (COM10) - PROPERTIES / DETAILS tab.....)
then the harware comes back with:
USB\VID_1FC9&PID_000C\ABCD
Now, the new inf file you kindly attached (LPC43xx-vcom.inf), refers to this line as
[DeviceList]
i.e. - the device name ending with '2002'.
I have changed this last line to read '000C', in accordance with what the hardware properties says, and it will then load the device driver.......but still not start the the device, with a CODE 10 error, as mentioned.
I have even tried modifying your new inf files to end with '...000C\ABCD', in case the 'ABCD' has aneffect...but no joy.
In my opinion, my hardware (bought from Element14) may have an 'old' hardware name of '000c', which all the current *.inf files won't affiliate to.
Do you think I should return the hardware and get new development card?
I would be interested to see what happens to anyone else, when they 'right-click' and look at the PROPERTIES/DETAIL tab with their device!
Can you please try?
All suggestions greatly appreciated.
Many thanks,
Manny
