How to change the xtal frequency slightly
lpcware
Content originally posted in LPCWare by Ivar on Mon Jul 14 20:32:21 MST 2014
Is there any way to change the xtal frequency slightly so that i can achive the desired working frequency.
My board with LPC1830 has a 12 Mhz xtal. The processor run with 120 MHz.
I want to change the frequency at about 20 kHz to minimize RF interference in another circuit. Is it possible to make this adjustment?
Thank you.
Ivar.
lpcware
Content originally posted in LPCWare by Ivar on Fri Jul 18 12:18:56 MST 2014
Ok, I'll try that.
Thank you very much.
Ivar
lpcware
Content originally posted in LPCWare by embd02161991 on Fri Jul 18 10:23:25 MST 2014
Changing the load capacitance on the crystal pins, may shift the frequency by a few percent. There will not be any drastic changes in frequency though.
NXP Technical Support
