Content originally posted in LPCWare by mplu on Tue Dec 22 05:13:20 MST 2015 My LPC1837 locked up after a bad clock config. The "r" and "h" command using jlink.exe is not working. I'm using IAR EWArm 6.50.3.
Content originally posted in LPCWare by vtw.433e on Tue Dec 22 08:58:47 MST 2015 You're screwed then. You can only recover by physically booting into ISP
Content originally posted in LPCWare by vtw.433e on Tue Dec 22 07:11:33 MST 2015 Boot into ISP mode, as described in the User Manual - or search this forum for details
