Content originally posted in LPCWare by chuckp on Wed Oct 10 06:22:19 MST 2012
I tried this once. I found that when I was running from SPIFI, accessing the SPIFI library killed the program. This makes some sense to me. In a program running from RAM I was able to write to the SPIFI using the library. I suspect, though I haven't tried, that you need to be sure you are not running out of SPIFI when you do the write. So try putting the code to program the SPIFI in RAM?
