lpcware
LPC18xx USB0_ID Pull up resistor value
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by nallison on Sun Nov 29 17:51:49 MST 2015
We're using the LPC1830 and our test engineer wants to know the value of the internal pull-up resistor on the USB0_ID pin. Refer e.g. UM10430, Table 170, page 325 where it says:
Quote:
USB0_ID
Indicates to the transceiver whether connected as an A-device
(USB0_ID LOW) or B-device (USB0_ID HIGH). For use with
OTG, this pin has an internal pull-up resistor
I have looked through the datasheet and user manual but found no numerical value for this pull-up resistor.  A brief search of the USB IF spec documents did not give me any data either.
Please direct me to the documentation that specifies the pull-up value for the LPC1830.
Thank you
Neil
