How to get uart working on LPC183x-Xplorer
lpcware
Content originally posted in LPCWare by ianlokejj on Wed Jun 25 07:55:57 MST 2014
Could anyone who has successfully transmitted data via UART explain how it is done on the Xplorer board?
I have tried using example code from http://docs.lpcware.com/lpcopen/v1.03/lpc18xx__43xx_2examples_2periph_2periph__uart_2uart_8c_source....  , however no text is displayed when it is being run.
I connected a ft232 breakboard board to U0_TXD, U0_RXD and Ground and tried to view the output on TeraTerm but didn't see anything.
May anyone help?
Ian
lpcware
Content originally posted in LPCWare by ianlokejj on Sat Jun 28 20:41:18 MST 2014
Thank you embd02161991 for pointing me to the latest projects, UART works fine now at a baud rate of 115200.
lpcware
Content originally posted in LPCWare by embd02161991 on Thu Jun 26 22:03:03 MST 2014
Have you tried the latest version v.2.12 of LPCOpen examples ?
http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc18xx-packages-0
The uart example uses UART0 with baud rate of 115200.
NXP Technical Support
