lpcware
Drivers for SPIFI N25Q064A
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Paulo Madeira on Tue Jan 19 12:31:40 MST 2016
We are using LPC1830 with Flash SPIFI from Macronix part number MX25L6445EZNI-10G and IAR
This memory is used as program and data memory and it is working properly.
We are now changing this memory for Micron part number N25Q064A13EW9D0F but it is not working.
It's possible to use an external programmer and run the main loop, but we can't write in this memory
(N25Q064A13EW9D0F) from LPC1830 for bootloader and data store purposes, although it works fine with MX25L6445EZNI-10G
We think that our SPIFI library (SPIFI_drv_M3.lib) does not support this Micron memory (this lib is from IAR 6.40).
We checked this forums, but this drivers has the same results or didn't worked:
https://www.lpcware.com/content/forum/spifi-does-not-work-n25q256
https://www.lpcware.com/content/forum/lpc1857-spifi-flash-loader-micron-n25q256a
Anyone can help us with this problem? Is there any new library that can handle this Micron N25Q memory?
Thank you.
