Content originally posted in LPCWare by jackandrews on Tue Sep 10 08:49:21 MST 2013
OK, a bit more info: disabling the Nagle algorithm (tcp_nagle_disable (xNetConn->pcb.tcp)) and reducing the test data length to 100 has got it working. However, I'd still like to work out how to send larger packets (e.g. 1kB) to reduce overhead (and increase throughput).
Jack
