lpcware
LPC1756 SoftConnect feature
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Linas on Sun Oct 28 12:23:24 MST 2012
In the datasheet I have found that in the bus-powered device I do not need to use SoftConnect pin in order
to pull D+ line. Instead I can use pull-up resistor.
In some other application notes for development kits I have found that it is recommended to use SoftConnect
pin in order to pull the D+ line by software.
What are the recommendations regarding SoftConnect functionality. My application implements USB device using LPC1756 MCU.
Linas
