lpcware
LPC1752 UID not in early chips?
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by mozmck on Mon Jan 21 14:35:08 MST 2013
I am reading the UID using IAP in LPC1752 chips, and it seems that the newer chips work fine, but a couple of older chips just return FFFFFFFF for 3 of the numbers and 0 for the first one.  The parts are all revision A, and the date code on the chips that return a valid number is 1215, the older ones that don't work are 1135.
Did the older chips not have a UID, or is there a different way to access it?  I can't find anything that says so.
