lpcware
Problem with programming LPC1768 by JLINK
Content originally posted in LPCWare by rebo on Tue Jun 25 00:40:07 MST 2013
Please Help...
I have a LPC1768 soldered on my PCB. For the first time, when the device was blank, it was programmed correctly. After that, JLINK cannot connect and program flash.
The error is as below:
Could not power up debug port: Control/Status register reads 00000F03
Failed to connect
I use "J-FLASH ARM V4.34a".
The external clock frequency is 8MHz.
The PLL setting is : M=150 , N=8
