Content originally posted in LPCWare by yasinidiz on Sun Jun 22 23:28:15 MST 2014
I'm trying to use example Bypass (founded peripherhal library) to use CAN. I ve tried all the jumper settings on my 1788 board but, i couldnt get any data from CAN1 or CAN2. Then I've set CAN as transmitter and scope directly to the pin but i couldnt see a CAN Data. What is the problem with this example?
