Content originally posted in LPCWare by yeqing85123 on Fri Jul 11 01:21:47 MST 2014 Hello, At first, sorry about my poor English. My problem is : I want to download f/w without reset mcu and set P2[10] to low,So I use the IAP RE-INVOKE ISP command.But when I start the flash magic , it shows "Failed to autobaud - step 1" just after the command sent. Bellow is the code which I invoke the command( according http://www.lpcware.com/content/blog/reinvoke-isp-user-code-example-lpc177x-lpc178x for simple example):
