LPC1785 CRP2 Upgrade Problem
lpcware
Content originally posted in LPCWare by Arnold.K on Tue Jan 29 18:37:03 MST 2013
Dear ALL,
I have two problems regarding upgrade the LPC 1785 after using the Level 2 Code Read Protection.
First, as CRP2 need to use the JTAG. I may want to ask can I use IAP to upgrade my code by UART? How can I do this? Also, is that we need to use P0(2) and P0(3).
Second, with the CRP2, can I use SD card to upgrade? If yes, how?
Thank you so much.
Best Regards
Arnold
Fustec
