void DMA_IRQHandler (void) { static uint32_t regVal; regVal=LPC_GPDMA->IntTCStat; LPC_GPDMA->IntTCClear |= regVal; regVal=LPC_GPDMA->IntErrStat; LPC_GPDMA->IntErrClr |= regVal; // check GPDMA interrupt on channel DMA_CHANNEL_NO //if (GPDMA_IntGetStatus(GPDMA_STAT_INT, DMA_CHANNEL_NO)){ //check interrupt status on channel DMA_CHANNEL_NO // Check counter terminal status //if(GPDMA_IntGetStatus(GPDMA_STAT_INTTC, DMA_CHANNEL_NO)){ // Clear terminate counter Interrupt pending //GPDMA_ClearIntPending (GPDMA_STATCLR_INTTC, DMA_CHANNEL_NO); //Channel0_TC++; //} //} } GPDMA_LLI_TypdGPDMA_LLI; void DMA_Setup() { uint32_ti=0; GPDMA_Channel_CFG_TypeGPDMACfg; for (i=0;i<512;i+=2) { DMASrc_Buffer=0x00; DMASrc_Buffer[i+1]=0xff; } NVIC_DisableIRQ(DMA_IRQn); NVIC_SetPriority(DMA_IRQn, ((0x01<<3)|0x01)); GPDMA_Init(); //Setup DMA Channel GPDMA_LLI.SrcAddr=(uint32_t)DMASrc_Buffer; GPDMA_LLI.DstAddr=(uint32_t)&(LPC_GPIO0->PIN); GPDMA_LLI.NextLLI=(uint32_t)&GPDMA_LLI; GPDMA_LLI.Control= DMA_SIZE |(2<<18) //SW=32Bit |(2<<21)//DW=32Bit |(1<<26) //source incr |(1<<31) ; GPDMACfg.ChannelNum=DMA_CHANNEL_NO; GPDMACfg.SrcMemAddr=(uint32_t)DMASrc_Buffer; GPDMACfg.DstMemAddr=(uint32_t)(&LPC_GPIO0->PIN); // Transfer size GPDMACfg.TransferSize = DMA_SIZE; // Transfer width GPDMACfg.TransferWidth = GPDMA_WIDTH_WORD; // Transfer type GPDMACfg.TransferType = GPDMA_TRANSFERTYPE_M2M; // Source connection - unused GPDMACfg.SrcConn = 0; // Destination connection - unused GPDMACfg.DstConn = 0; // Linker List Item - unused GPDMACfg.DMALLI = (uint32_t)&GPDMA_LLI; // Setup channel with given parameter GPDMA_Setup(&GPDMACfg,0); // Enable GPDMA channel DMA_CHANNEL_NO GPDMA_ChannelCmd(DMA_CHANNEL_NO, ENABLE); /* Enable GPDMA interrupt */ NVIC_EnableIRQ(DMA_IRQn); } |
