In that article i found the pinout of the display module. Can i connect that wires to any Port of the 1769? Also i ask myself if i can use the UTFT library which was used in that article on the LPCXpresso. And if i use that library, is it then necessary to have a specific wiring?
Content originally posted in LPCWare by xianghuiwang on Mon Feb 09 16:06:56 MST 2015 Hi, p4dman, You can use any port, but make sure your data bus and address bus are each on a single port. regards,
