Celso Monteiro
Significant Current Increase when programming flash  08QG8
Discussion created by Celso Monteiro on May 7, 2008
Latest reply on May 15, 2008 by Celso Monteiro
I was working on a flash programming problem in QG8 BDM, SSDD. I realized that when flash programming was in course some Hiwave messages appear and the operation was aborted - Great news! I've been thru this at least 10 times before, specially in crytical phases - but the symptoms were quite different this time.
I've noticed a sudden current increase in current and due to shunt regulator topology, the current was over the "specs worst case" and the uP voltage dropped and caused the malfunction.
I can imagine that the flash charge pump could add some extra miliamps, but the boot of the charge pump really turned my regulator down.
I couldn't find on the specs any idea on this burst current, does anyone have a clue on what could be (worst case)?
Tks in advance,
Cheers,
Celso
Added p/n to subject.
Message Edited by NLFSJ on 2008-05-07 07:36 AM
