lpcware
LPC1788 and SDRAM
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by marcolando on Fri Feb 12 11:58:15 MST 2016
Hy guys,
I think I've a problem with an SDRAM (Micron MT48LC4M32) connected to the processor.
After the initialization I run a very very simple test:
long EMC_Test(void)
{// test SDRAM
long * SDRAM_ptr = RAM_BASE;
long i, count;
count = 0;
for (i = 0; i < RAM_CELL; i++)
{// write data
*SDRAM_ptr = i;// write data to SDRAM
if(*SDRAM_ptr++ == i)
count++;
return (count >> 6);// return value in kByte
and doing so it works...
but if I do the same test splitting write to memory and read from memory in two separate loops the test fails...
long EMC_Test(void)
{// test SDRAM
long i, count;
count = 0;
{// write data
*SDRAM_ptr++ = i;// write data to SDRAM
{// read data
if(i == *SDRAM_ptr++)// read data from SDRAM
count++;
Any ideas to start my investigation?
Thank you very much in advance,
Marco.
