Content originally posted in LPCWare by FrankAndersen on Wed Jul 17 04:39:14 MST 2013
MCU is LPC1788.
I am using the DAC together with DMA ch1 to play sounds, must of the time, it works, but sometimes it stops working, the error is hard to reproduce, and I have not yet been able to reproduce very often.
The DMA transfer does not end, and when the error happens, even thoug I init the DMA channel again, it does not start.
The source for the DMA is external flash.
Any one out there using the DAC together with the DMA?
Frank Andersen
