[REQ] lpc1768 and w5100
lpcware
Content originally posted in LPCWare by gbg on Mon Nov 24 06:25:25 MST 2014
i want use w5100 in SPI mode
Does anyone have a sample program?
lpcware
Content originally posted in LPCWare by Mohsenavr on Sun Mar 08 08:10:15 MST 2015
what I found are for AVR!
link
I'm trying to found out the routine.....
lpcware
Content originally posted in LPCWare by gbg on Sun Mar 08 02:49:22 MST 2015
NO
i can not use it
lpcware
Content originally posted in LPCWare by Mohsenavr on Sun Mar 08 00:57:56 MST 2015
Hi gbg,
did you port w5100 finally?
can i have your sample code?
lpcware
Content originally posted in LPCWare by rocketdawg on Wed Nov 26 16:05:10 MST 2014
http://www.wiznet.co.kr/
there is a driver in the download section.  minimal effort to port it.
lpcware
Content originally posted in LPCWare by gbg on Mon Nov 24 11:49:13 MST 2014
Ok,Thanks
Speed is not important for me , I want use w5100 in SPI mode.
I اhave w5100 module.
lpcware
Content originally posted in LPCWare by rocketdawg on Mon Nov 24 11:40:32 MST 2014
you do not want to do that
You can download the W5100 performance report from No. 76 of FAQ in website.
Direct bus supports maximum speed 2.8Mbps. SPI supports maximum 0.3Mbps.
W5200 is faster, w5500 even more
