Content originally posted in LPCWare by karanmehta93 on Mon Oct 15 07:05:50 MST 2012
1. What is the basic difference between RIT and timer in LPC1769 ?
If I want a code to generate a delay of n microseconds how can I do it?
2.How to use the index pin provided with QEI?
3. If i use one encoder with one capture and I want to record it's velocity how many timers will be needed??
4.Explain me THRE interrupt
