Content originally posted in LPCWare by ktownsend on Tue Nov 08 15:24:14 MST 2011
No RTOS is required for emWin, and by default it is configured to run without one. The timing is based on a systick timer delay that is used to poll the ADC, and other tasks requiring a delay.
There is very thorough documentation available in the installer packages in the /doc folder, along with a large collection of examples that should be a good starting place to begin using emWin (/Start/Samples).
I hope this helps,
Kevin
