Content originally posted in LPCWare by nav070887 on Sat Dec 28 22:43:29 MST 2013
This might be a stupid problem on my end, but after I program the lpcxpresso 1769 using the Program Flash utility provided by the LPCxpresso eclipse ide, reset the power, the program doesn't seem to hold in flash memory. Nothing runs..It doesn't work after power reset (physically unplugging USB cable and plugging it back in)
Any help will be appreciated..
Thank you
Nav
