lpcware
SysTick Interrupt Disable generates HardFault
Latest reply on Jan 24, 2019 by Thasin Akhand
Content originally posted in LPCWare by lokinhas on Wed Oct 29 03:05:18 MST 2014
Hi everyone.
In my current project I'm using a LPC1788 with the SysTick acting has a global timer, for non blocking code, the problem is that when a function needs to disable momentary the SysTick the interrupt (SysTick_IRQn) a HardFault occurs.
In the past I've used several LPC microcontrollers with a Cortex-M0 core (LPC1227, LPC11U68, etc) with the exact same code, without problems.
In attachment there's a example project that you can try.
Thanks in advance for the help.
Original Attachment has been moved to: FW.zip
