Content originally posted in LPCWare by anuj.tanksali on Tue Sep 02 03:27:31 MST 2014
Thanks for your reply. I verified the data and addresses 2 to 3 times. it is correct and the i get same values every time. still the issue remains.
my scatter file for SDRAM is below
LR_RAM2 0x0xA1000000 0x00E00000 {
01_CodeFile 0xA1000000 0x00E00000 {
*(CALIB72, CALIB48, CALIB28, CALIB24, CALIB20, BCKGND , SCR_SPF, SCR_PV, SCR_IRRA, SCR_BIO, UP_ARW, DN_ARW, SCR_SET, SCR_MAT, BCKDES, CLICK, BEEP, ENDOP, SCONN, RED_BUTTON, RED_BUT_MATERIAL)
is it because i have defined the sections and not fixed addresses. I plan to hard code the addresses and again check.
Anuj
