Content originally posted in LPCWare by erdoganguler on Mon Apr 21 23:14:08 MST 2014
I am using lpc1768. I can read data from CAN Line without any problem but I cant send any message. I tried "normal operatıon mode- self test mode and global test mode"
I dont think the problem is about Clock settings because I can read messages.
I tried to write own code . It didnt work. then I use keil examples for lpc17xx. It didnt work either.
Original Attachment has been moved to: can%20problem.rar
Hi Erdogan,
If also the Keil example does not work, it's most likely a hardware issue. Which board are you using? You can also try running the LPCOpen CAN examlpe, which works for sure.
Wouter
