Content originally posted in LPCWare by atul.koolkarni on Sat Apr 04 05:15:25 MST 2015
Hello There,
I am trying to migration the CAN peripheral sample to the Keil RTX. The implementation also has EMAC (ethernet) support. There seems to be some problem of memory map which I am not able to understand. The ethernet interface does not work when CAN init is done.
Are there any known issues on that side someone has experienced earlier?
atul
