Different library files with identical revision info
lpcware
Content originally posted in LPCWare by ezharkov on Fri Aug 23 10:10:15 MST 2013
I started with the LPC with an Embedded Artist's kit and downloaded some source libraries for that.
Later I came across http://www.lpcware.com/system/files/lpc177x_8x_08132012.zip on this site.
Many files have identical revision info, but are completely different.
lpc177x_8x_i2c.c, for example.
Both versions are:
* @version1.0
* @date02. June. 2011
* @authorNXP MCU SW Application Team
But otherwise the files are quite different.
What is going on?!
lpcware
Content originally posted in LPCWare by lpcadmin on Fri Aug 23 14:22:44 MST 2013
Hi ezharkov,
We are sorry for the confusion and obvious problem with an outdated/not maintained header comment blocks.
The code base on www.lpcware.com is the most current, so please use that code.
We are working on our LPCOpen v2.00 release, which has a different comment header style and will not have this problem.
Again, we are sorry for the confusion.
-LPCadmin
