Content originally posted in LPCWare by panneerrajan on Mon Mar 10 04:09:15 MST 2014 Hi,
We have used LPC2478 with 4.3 & 7” TFT LCD with touch screen through RGB Interface (8*3= 24BIT). In future we have to use LPC2478/LPC1788 with 10.1” TFT LCD with touch screen. The 10.1” LCD has 18 bit with LVDS interface. How to interface the LPC2478/LPC1788 with 10.1” TFT LCD via LVDS interface? Kindly give me the suggestion for the same
Content originally posted in LPCWare by vvijayan75 on Fri Jul 25 04:05:07 MST 2014 hi panneerrajan, you said you worked in 10.1" TFT LCD .MAY I know the value for hsync,vsync,and pulse width for horizontal /vertical? can you help me to how to make work TFT lcd ?in which manner you wrote a driver for TFT ?
Content originally posted in LPCWare by Martin84 on Mon Mar 10 07:28:49 MST 2014 Hi,
you will need an LVDS Transmitter, which is compatible to the Display's LVDS Interface. Then you can use the RGB-Interface of the µC to drive the LVDS Transmitter. Perhaps you find a recommendation for a LVDS Transmitter in the displays datasheet.
