Content originally posted in LPCWare by Wouter on Fri Oct 25 04:25:13 MST 2013
Looks like the behavior of the spinbox was changed in V5.22. You can now select which digit you want to increment/decrement by touching that digit. Default the least-significant digit should be selected, but from your description it sounds like the most-significant digit is selected. Can you try selecting the least-significant digits first, then hit increment/decrement?
Wouter
