emWin memry allocation for widgets
lpcware
Content originally posted in LPCWare by johanan on Sun May 26 06:47:08 MST 2013
I would like to make a screen which will be populated with diferrent widgets at run time.
This looks possible, but I have no idea on emWin method for allocating memry and releasing when widgets are no longer needed.
The best would be to have my own buffer with constand size ( enogh for the most populated screen), which will hold all current widgets, and when I remove and change the widgets, I will erase that buffer and start over.
Is there a way to do it?
thanks
Johanan
lpcware
Content originally posted in LPCWare by mc on Fri Jun 07 18:51:54 MST 2013
Hi Johanan,
Please check memory devices feature of emWin. You can check it at
<a href="http://www.segger.com/memory-devices.html">http://www.segger.com/memory-devices.html</a>
NXP Support
