lpcware
Having trouble creating dual frame buffer on LCP32xx
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by brothwell on Tue Mar 26 11:21:26 MST 2013
I am trying to modify my app to use dual frame buffers on the LPC32XX system.   Using a single frame buffer works fine ( TFT / VGA / 24 bit).  When I attempt to switch frame buffers using the LCD_UPBASE register while "hot", the screen appears to freeze.
I suspect I need to do some other steps prior to swapping the register, but the User Manual has no guidance.
Any suggestions would be helpful.
