Content originally posted in LPCWare by Ildar on Fri Jul 13 07:41:15 MST 2012
We have custom board based on LPC1788. We have ported linux on it. And we trying use NXP_emWin516_libraries from this site. But emwin crahed in GUI_Init() function!
There is dump of registers:
SIGNAL: 11 (SIGSEGV)
BACKTRACE:
error_code: 0x0 fault_address: 0x0 pc: 0xa180a640 cpsr: 0x21000000 lr: 0xa180b311 sp: 0xa1a39de0
ip: 0xfffffb00 fp: 0x0 trap_no: 0x0 oldmask: 0x0 r0: 0xf0 r1: 0x4ab00 r2: 0x0
r3: 0x4ab00 r4: 0x130 r5: 0x0 r6: 0x0 r7: 0xf0 r8: 0x140 r9: 0x140 r10: 0xa182c2ed
The error occurs in function _FillRect and call from LCD_FillRect. Program try write to address 0! Why? In LCD_X_DisplayDriver in LCDConf.c I write:
case LCD_X_SETVRAMADDR: {
// Required for setting the address of the video RAM for drivers
// with memory mapped video RAM which is passed in the 'pVRAM' element of p
LCD_X_SETVRAMADDR_INFO * p;
p = (LCD_X_SETVRAMADDR_INFO *)pData;
int fd;
unsigned int* fbp;
long int screensize = 320 * 240 * 2;
* Open the framebuffer device file
fd = open("/dev/fb0", O_RDWR);
if (fd == -1) {
perror("Error: cannot open framebuffer device");
exit(1);
* Map the device to memory
fbp = (unsigned int *)mmap(
0, screensize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
if ((int)fbp == -1) {
perror("Error: failed to map framebuffer device to memory");
exit(5);
//p->pVRAM = malloc((1024 * 1024) * 2);
p->pVRAM = fbp;
printf("\np = 0x%x pData = 0x%x p->pVRAM = 0x%x\n", p, pData, p->pVRAM);
return 0;
So virtual address is not null! What am I doing wrong?
0000a484 <_FillRect>:
a484:e92d 43f7 stmdbsp!, {r0, r1, r2, r4, r5, r6, r7, r8, r9, lr}
a488:6884 ldrr4, [r0, #8]
a48a:460d movr5, r1
a48c:6b27 ldrr7, [r4, #48]; 0x30
a48e:4616 movr6, r2
a490:f8dd 8028 ldr.wr8, [sp, #40]; 0x28
a494:b147 cbzr7, a4a8 <_FillRect+0x24>
a496:4c44 ldrr4, [pc, #272]; (a5a8 <_FillRect+0x124>)
a498:f8cd 8000 str.wr8, [sp]
a49c:6824 ldrr4, [r4, #0]
a49e:6824 ldrr4, [r4, #0]
a4a0:9401 strr4, [sp, #4]
a4a2:6980 ldrr0, [r0, #24]
a4a4:47b8 blxr7
a4a6:e07d b.na5a4 <_FillRect+0x120>
a4a8:f1c1 0901 rsbr9, r1, #1
a4ac:4499 addr9, r3
a4ae:4b3f ldrr3, [pc, #252]; (a5ac <_FillRect+0x128>)
a4b0:f1c2 0701 rsbr7, r2, #1
a4b4:7c1b ldrbr3, [r3, #16]
a4b6:4447 addr7, r8
a4b8:f013 0f01 tst.wr3, #1
a4bc:f8d4 801c ldr.wr8, [r4, #28]
a4c0:d020 beq.na504 <_FillRect+0x80>
a4c2:6903 ldrr3, [r0, #16]
a4c4:689b ldrr3, [r3, #8]
a4c6:4798 blxr3
a4c8:69e3 ldrr3, [r4, #28]
a4ca:fb03 5506 mlar5, r3, r6, r5
a4ce:f1b9 0f00 cmp.wr9, #0
a4d2:d067 beq.na5a4 <_FillRect+0x120>
a4d4:1e7e subsr6, r7, #1
a4d6:ea4f 0c88 mov.wip, r8, lsl #2
a4da:fb08 5806 mlar8, r8, r6, r5
a4de:f1cc 0c00 rsbip, ip, #0
a4e2:ea4f 0888 mov.wr8, r8, lsl #2
a4e6:e00a b.na4fe <_FillRect+0x7a>
a4e8:3f01 subsr7, #1
a4ea:4643 movr3, r8
a4ec:464a movr2, r9
a4ee:6821 ldrr1, [r4, #0]
a4f0:585d ldrr5, [r3, r1]
a4f2:4045 eorsr5, r0
a4f4:505d strr5, [r3, r1]
a4f6:3304 addsr3, #4
a4f8:3a01 subsr2, #1
a4fa:d1f8 bne.na4ee <_FillRect+0x6a>
a4fc:44e0 addr8, ip
a4fe:2f00 cmpr7, #0
a500:d1f2 bne.na4e8 <_FillRect+0x64>
a502:e04f b.na5a4 <_FillRect+0x120>
a504:fb08 1502 mlar5, r8, r2, r1
a508:6823 ldrr3, [r4, #0]
a50a:f1b9 0f0f cmp.wr9, #15
a50e:eb03 0585 add.wr5, r3, r5, lsl #2
a512:4b25 ldrr3, [pc, #148]; (a5a8 <_FillRect+0x124>)
a514:681b ldrr3, [r3, #0]
a516:681a ldrr2, [r3, #0]
a518:d92d bls.na576 <_FillRect+0xf2>
a51a:f107 4380 add.wr3, r7, #1073741824; 0x40000000
a51e:ea4f 0188 mov.wr1, r8, lsl #2
a522:3b01 subsr3, #1
a524:f1c1 0c00 rsbip, r1, #0
a528:4638 movr0, r7
a52a:fb01 5103 mlar1, r1, r3, r5
a52e:2500 movsr5, #0
a530:e01d b.na56e <_FillRect+0xea>
a532:464c movr4, r9
a534:460b movr3, r1
a536:3c10 subsr4, #16
THIS ADDRESS (a538) is PC (0xa180a640) We try write to 0 and crash (SEGMENTATION FAULT)!
a538:601a strr2, [r3, #0]
a53a:605a strr2, [r3, #4]
a53c:609a strr2, [r3, #8]
a53e:60da strr2, [r3, #12]
a540:611a strr2, [r3, #16]
a542:615a strr2, [r3, #20]
a544:619a strr2, [r3, #24]
a546:61da strr2, [r3, #28]
a548:621a strr2, [r3, #32]
a54a:625a strr2, [r3, #36]; 0x24
a54c:629a strr2, [r3, #40]; 0x28
a54e:62da strr2, [r3, #44]; 0x2c
a550:631a strr2, [r3, #48]; 0x30
a552:635a strr2, [r3, #52]; 0x34
a554:639a strr2, [r3, #56]; 0x38
a556:63da strr2, [r3, #60]; 0x3c
a558:3340 addsr3, #64; 0x40
a55a:2c0f cmpr4, #15
a55c:d8eb bhi.na536 <_FillRect+0xb2>
a55e:f1a9 0510 sub.wr5, r9, #16
a562:092d lsrsr5, r5, #4
a564:3501 addsr5, #1
a566:01ad lslsr5, r5, #6
a568:194d addsr5, r1, r5
a56a:3801 subsr0, #1
a56c:4461 addr1, ip
a56e:2800 cmpr0, #0
a570:d1df bne.na532 <_FillRect+0xae>
a572:f009 090f and.wr9, r9, #15
a576:f1b9 0f00 cmp.wr9, #0
a57a:d013 beq.na5a4 <_FillRect+0x120>
a57c:f107 4380 add.wr3, r7, #1073741824; 0x40000000
a580:ea4f 0888 mov.wr8, r8, lsl #2
a584:3b01 subsr3, #1
a586:f1c8 0000 rsbr0, r8, #0
a58a:fb08 5503 mlar5, r8, r3, r5
a58e:e007 b.na5a0 <_FillRect+0x11c>
a590:4629 movr1, r5
a592:464b movr3, r9
a594:3b01 subsr3, #1
a596:f841 2b04 str.wr2, [r1], #4
a59a:d1fb bne.na594 <_FillRect+0x110>
a59c:3f01 subsr7, #1
a59e:182d addsr5, r5, r0
a5a0:2f00 cmpr7, #0
a5a2:d1f5 bne.na590 <_FillRect+0x10c>
a5a4:e8bd 83fe ldmia.wsp!, {r1, r2, r3, r4, r5, r6, r7, r8, r9, pc}
a5a8:000345ac .word0x000345ac
a5ac:00238490 .word0x00238490
0000b1c0 <LCD_FillRect>:
b1c0:b573 push{r0, r1, r4, r5, r6, lr}
b1c2:4e12 ldrr6, [pc, #72]; (b20c <LCD_FillRect+0x4c>)
b1c4:460c movr4, r1
b1c6:f9b6 500c ldrsh.wr5, [r6, #12]
b1ca:f9b6 1008 ldrsh.wr1, [r6, #8]
b1ce:42aa cmpr2, r5
b1d0:bfb8 itlt
b1d2:4615 movltr5, r2
b1d4:4288 cmpr0, r1
b1d6:bfa8 itge
b1d8:4601 movger1, r0
b1da:428d cmpr5, r1
b1dc:db14 blt.nb208 <LCD_FillRect+0x48>
b1de:f9b6 200a ldrsh.wr2, [r6, #10]
b1e2:f9b6 000e ldrsh.wr0, [r6, #14]
b1e6:4294 cmpr4, r2
b1e8:bfa8 itge
b1ea:4622 movger2, r4
b1ec:4283 cmpr3, r0
b1ee:bfa8 itge
b1f0:4603 movger3, r0
b1f2:4293 cmpr3, r2
b1f4:db08 blt.nb208 <LCD_FillRect+0x48>
b1f6:7c70 ldrbr0, [r6, #17]
b1f8:eb06 0680 add.wr6, r6, r0, lsl #2
b1fc:6cf0 ldrr0, [r6, #76]; 0x4c
b1fe:68c4 ldrr4, [r0, #12]
b200:9300 strr3, [sp, #0]
b202:6924 ldrr4, [r4, #16]
b204:462b movr3, r5
b206:47a0 blxr4
THIS ADDRESS (b208) is LR (0xa180b311)
b208:bd7c pop{r2, r3, r4, r5, r6, pc}
b20a:bf00 nop
b20c:00238490 .word0x00238490
