#ifdef __cplusplus extern "C" { #endif void WDT_IRQHandler(void) { WatchDog::instance().handleIRQ(); } #ifdef __cplusplus } #endif void WatchDog::handleIRQ() { uint32_t wdt_status = Chip_WWDT_GetStatus(_reg); // warning interrupt if (wdt_status & WWDT_WDMOD_WDINT) { if(_warning_fnc != NULL) { _warning_fnc(); } Chip_WWDT_ClearStatusFlag(_reg, WWDT_WDMOD_WDINT); } // timeout interrupt if (wdt_status & WWDT_WDMOD_WDTOF) { if(_timeout_fnc != NULL) { _timeout_fnc(); } Chip_WWDT_ClearStatusFlag(_reg, WWDT_WDMOD_WDTOF); } } |
void wdt_wrn_irq() { Debug::instance() << "WDT warning " << gbl_sw.elapsedMS() << endl; } void wdt_rst_irq() { Debug::instance() << "WDT timeout " << gbl_sw.elapsedMS() << endl; } |
WatchDog& wdt = WatchDog::instance(); wdt.init(); wdt.setTimeOutFunction(wdt_rst_irq); wdt.setTimeOutMode(WDT_TO_Interrupt); wdt.setTimeOutMS(5000); // wdt.setWarningUS(50000); // wdt.setWarningFunction(wdt_wrn_irq); if(wdt.start()) { Debug::instance() << "WDT started" << endl; } |
WatchDog& wdt = WatchDog::instance(); wdt.init(); wdt.setTimeOutMode(WDT_TO_Interrupt); wdt.setTimeOutMS(5000); wdt.setTimeOutFunction(wdt_rst_irq); wdt.setWarningUS(50000); wdt.setWarningFunction(wdt_wrn_irq); if(wdt.start()) { Debug::instance() << "WDT started" << endl; } |
WDT started WDT warning 4711 WDT timeout 4713 |
WDT started WDT warning 4710 |
