emWin 5.28 release
emWin 5.28 release
lpcware
Content originally posted in LPCWare by giusloq on Fri May 22 22:54:33 MST 2015
Hello NXP support,
on emWin forum managed by Segger, we found a bug on 5.26 release. The bug was fixed in 5.28, that is the latest release. I need this bug fix for my project with NXP MCUs.
When are you going to release the 5.28 pre-compiled emWin libraries for NXP MCUs? I hope soon.
One request.
In the evaluation version, Segger releases pre-compiled library compiled with mingw compiler too. This is useful for simulation under Windows OS without using Visual Studio IDE. For example, I use Code::Blocks with mingw compiler. It is much more faster and more similar to GNU ARM toolchain.
I hope also NXP will release the mingw pre-compiled emWin libraries.
