lpcware
Can't connect lpclink2
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by jerrylwb on Fri Aug 01 00:26:12 MST 2014
    I am tring the lpcexpresso board 1549 and I had compile and run the "blinky" sample successfully with Ebed yesterday. Today  I want to configurate the plclink2 use DFU programmer(LPC_Link2_Config_tool_v1_11_1) as jlink, due to use the IAR IDE .
    But It's a pity that the programming field! And even I can't connect the lpclink2 , the programme software can't find usb(see attached image). I thought that the LPC4322 need to programmed again ,how to programme it?  where is the bin file?
