lpcware
LPC 1227 and GPIO
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by drvrh on Tue Jul 21 03:42:23 MST 2015
I wrote my library for GPIO for LPC1227 and working in past but now doesn't work.
I have in main:
GPIOSetDir(0, 16, OUTPUT);
GPIOSetValue(0, 16, LOW);
In IO.c I have:
void GPIOSetValue( uint32_t portNum, uint32_t bitPosi, uint32_t bitVal )
  if (bitVal == 0)
  switch (portNum) {
case 0:
LPC_GPIO0 -> CLR = (1 << bitPosi);
break;
case 1:
LPC_GPIO1 -> CLR = (1 << bitPosi);
break;
case 2:
LPC_GPIO2 -> CLR = (1 << bitPosi);
default:
break;
  else if (bitVal >= 1)
  switch (portNum){
  case 0:
  LPC_GPIO0 -> SET = (1 << bitPosi);
  break;
  case 1:
  LPC_GPIO1 -> SET = (1 << bitPosi);
  break;
  case 2:
  LPC_GPIO2 -> SET = (1 << bitPosi);
  break;
void GPIOSetDir( uint32_t portNum, uint32_t bitPosi, uint32_t dir )
  if(dir)
  switch (portNum) {
case 0:
LPC_GPIO0-> DIR |= 1 << bitPosi;
break;
case 1:
LPC_GPIO1-> DIR |= 1 << bitPosi;
break;
case 2:
LPC_GPIO2 -> DIR |= 1 << bitPosi;
break;
default:
break;
  else
  switch (portNum) {
case 0:
LPC_GPIO0 -> DIR &= ~(1 << bitPosi);
break;
case 1:
LPC_GPIO1 -> DIR &= ~(1 << bitPosi);
break;
case 2:
LPC_GPIO2 -> DIR &= ~(1 << bitPosi);
break;
default:
break;
Where I have a problem?
Original Attachment has been moved to: IO_0.c.zip
Original Attachment has been moved to: IO_0.h.zip
